ls6 ls2 manifold
Old Feb 11, 2007 | 02:46 PM
Rick. Salinas's Avatar
Default ls6 ls2 manifold
i have a ls6 without the manifold. will it be a problem if i get a ls2 manifold or will i need some tweeking to do?
Old Feb 11, 2007 | 10:30 PM
rocketman69's Avatar
Well...if you use the LS2 manifold, you'll need the LS2 throttle body. The LS2s use the 90mm drive by wire throttle body used in the C6 vette, and GTO. They have a square 4 bolt pattern, compared to the triangular 3 bolt pattern found on the LS1/LS6.
