Ls1/2 Swap...what am I missing?
Old Feb 20, 2007 | 01:42 PM
SilencerNate's Avatar
Question Ls1/2 Swap...what am I missing?
Alright...what am I missing? Doing the swap from a '02 Camaro Z28. I know I'm missing a few things, but this is my first swap, so that's why I'm here.
Parts to KEEP from the swap:
Camaro-style Oil Pan (Use old LS1 pan)
Holley 90MM Throttle Body
LS1 Camshaft
Oil and water plugs, main cap side bolts
Valley cover, front cover, timing chain, timing chain damper, crank key, lifter trays, bolts, dowels, and plugs.
(Unsure)~~~~~~~~~~~
Head Gaskets
LS1 Lifters
LS1 Cylinder head Studs
Flywheel -Will the stock M6 hang, or need a replacement?
PARTS to BUY:
Short block: http://www.texas-speed.com/shop/item...id=684&catid=3
KAT-A4757 Injector adapter harness kit: http://www.katechengines.com/street_...tail.php?id=21
KAT-4751 LS2 / LS7 MAP extension harness: http://www.katechengines.com/street_...tail.php?id=21
LS1- LS2 knock sensor relocation harness adapter: http://www.lingenfelter.com/store/rx-ls2-ksrh.html
LS1- LS2 cam sensor adapter harness: http://www.lingenfelter.com/store/rx-ls2-csah.html
Oil Pump, 1997-05 LS1/LS6/LS2 Heavy-Duty: http://www.slponline.com/view_product.asp?P=55001
Timing Chain, 2005-07 LS2 Double-Roller: http://www.slponline.com/view_product.asp?P=55003
And a head/cam package. I still haven't decided on a certain one I like. This is going to be meant for street, with maybe track time 2-3 times every 2 months. As tempting as the big cams are, I'm trying to keep it relatively steady idle, with just a hint I'm not running a stock engine. Any ideas would be great.
Old Feb 20, 2007 | 02:56 PM
TNTramair's Avatar
when you order your block, TSP will supply you with everything you need for a ls1/ls2 swap.
i got the same block from them for forced induction....man its nice. cant wait to get everything together and crank it over.
goodluck
Old Feb 20, 2007 | 03:28 PM
goodluck
You're kidding me. So I've spend the last 3 days or so looking for parts I'm not even going to need?
Short block, not full crate right? Not the SLP kit. I just am about to shoot myself thinking about how much headaches I was having trying to get everything, and without even thinking to ask about whether of not Texas would include that as part of the package if that's the case.
Old Feb 20, 2007 | 04:49 PM
TNTramair's Avatar
lol...yeah. i got my 402 shortblock from them and they gave me every part i needed for the conversion. it costs extra obviously but they have you covered from pan to intake if you need it.
goodluck.
