6.0 Engine Help
Old Feb 25, 2007 | 09:19 PM
1999ssls1's Avatar
Default 6.0 Engine Help
I just got my crank and pistons in and motor wont turn. I am manualy turning it with 150ft/lb. The crank is fine and how its suppossed to be. The rings are hellfire and are file fit. I filled them to 22 and after just the first piston it was hard to turn. It is easy when the piston is on top or bottom, but when they get half way up it gets hard to turn. Someone please help
Thanks,
Michael
Old Feb 25, 2007 | 09:36 PM
StreetStalkerZ's Avatar
Either your side clearance on the rods are to tight or you have the main caps backwards. What is the clearance or have you checked them?
Old Feb 26, 2007 | 07:13 AM
1999ssls1's Avatar
We have checked both twice.
