4L80E w/05 gto LS2 issues.
Old Mar 7, 2007 | 12:09 AM
nsaltwater's Avatar
Default 4L80E w/05 gto LS2 issues.
I have an '05 LS2 with a M6 engine harness and ECM. This will be mated with an 2000 4L80E and installed in a rockcrawler. For the past several days I have talked with so many people about this setup and it seems like I keep getting different opinions.
1. Is there a program that will allow the factory ECM to control a 4L80E?
I've been told that since the LS2 did not come with a 80E, there is no VIN to use for a program??????
2. I would have to add a TCM to the M6 harness. Which TCM would I need???
3. Is the GTO pedal the only pedal to work this ECM?
Thanks for all your help.
Scott
Old Mar 7, 2007 | 05:58 AM
StingrayCrazy's Avatar
Scott
Scott,
Easy... Since you have the M6 and fly by wire I would buy a stand alone transmission controller or convert the tranny to full manual control. Transgo has a kit that will make the 4l80e manual shift by cable for HD/race applications.
Harder... If you wanted both to work together try to find a GMC 2005 Express van with the 6.0L/4l80e and use that PCM and harness. However that would be the end of your fly by wire and you would need to get a different throttle body as well as HP Tuners or the like for programming.
Good Luck
Frank
Old Mar 7, 2007 | 01:48 PM
Z'mnypit's Avatar
HPTuners fixed my .bin file and sent it back to me for the PCM to control the 4l80e in my 99 Z28. I got the wiring harness from speartech, just wire it to the PCM (has instructions) and then load the new OS from HPtuners and the PCM will control the shifts and etc for the 4l80e. Mine works like a champ.
Old Mar 7, 2007 | 03:24 PM
'JustDreamin''s Avatar
Yeah, this shouldn't be that hard. I certainly wouldn't go buying a standalone controller for something that is easily fixed.
The 3/4 ton Silverados have 6.0L, drive by wire, and 80E's, so a stock PCM is plenty capable of doing what you're asking.
And this is the kind of thread that would probably get much better responses in the Conversions & Hybrids forum, since that's what you're talking about (and building).
'JustDreamin'
Old Mar 7, 2007 | 05:06 PM
joshluther's Avatar
I have an 06' express van with a 6.0l and 4l80e pcm. I need a truck pcm. Maybe we can work something out.
Old Mar 8, 2007 | 08:15 AM
nsaltwater's Avatar
If this needs to be moved, I ask the mods to do so. But there are many who have complained about the failure rate of the 60E and are interested in a 80E swap. I have not found much information on using this tranny with a stock ecm. If a stock ECM from the gto will not control a 80E, I think that's important for all to know.
Now, will the express van with the 6.0L and 4l80E ecm plug directly into the gto harness? (I will have to have my harness modified anyway. Just curious if it's the same ecm type.)
Does it matter which tcm I use? 60E or 80E?
Last thing. Most shops offer ecm programing for $200-350. Can I buy HPtuners and accomplish the same?
Thanks again for helping with the newbie questions.
Scott
Old Mar 8, 2007 | 11:54 AM
I don't know for certain if the GTO PCM can run the 4L80E....But somebody ought to know.
I do know the F-body one can do it, because I've got one in my Bravada (and there are numerous F-bodies with an 80E). My program is for a basically stock 6.0L / 80E for a '03 Silverado 2500.
Yes, the 4L60E is a real POS.
There are a couple of wiring differences between a 4L60E and an 80E. Two wires which control the TCC are in different locations (different pins on the big grey connector on the trans). Two additional wires need to be moved to the Input Shaft Speed sensor (ISS) in order for that to work (although the trans will run ok without the ISS). So, basically, the total number of wires is correct, but 3 or 4 of them are used differently (and some need to change on both the trans end and the PCM end).
'JustDreamin'
