L92/L76 + Thunder CheatR in an LS2 = ???
Old Mar 7, 2007 | 08:51 PM
josh99ta's Avatar
Sold The Fun Stuff :(
Default L92/L76 + Thunder CheatR in an LS2 = ???
I have an 06 A4 GTO and I want more a little more go but I'm not interested in a max effort setup as this is a daily driver. I'm looking at putting a relatively small stall in it (Yank SS 3000 or similar) and leaving the stock gearing in it was well. Obviously I'm interestd in the L92/L76 setup for it's value and great performance but I'm looking for a cam to pair with it that would work well with the smaller stall, have a stock-like idle, basically drive like stock and I'd like to keep the stock manifolds with high flow cats, an x-pipe, and a catback but still put down some good power. With the A4 and the stall I'd still like to see somewhere in the neighborhood of 400+rwhp and traps in the upper 11X range. I'm just wondering if the CheatR cam would be a great choice for this application or if I should look elsewhere.
Old Mar 10, 2007 | 11:23 PM
2k2blkss's Avatar
ttt...
I'm also looking into this same setup. Maybe even the LPE GT-11, how it would work with the L92/L76 Combo also.
Old Mar 11, 2007 | 12:01 AM
ChrisUlrich's Avatar
Mmm... I like your thinking. But i'd recommend short headers at the least. Maybe even mids. 400whp on stock manifolds might be hard to accomplish. But I guess it's very feasible considering you would be well over 400whp if you had Long Tubes. I know they restrict... but can they be restricting 50whp?
Old Mar 11, 2007 | 01:17 AM
Bring the Noise's Avatar
With the stock exhaust manifolds it may be a little difficult.
Look at either the JBA or Edelbrock shorties.
The SLP kit with shaved L92 heads (64cc chamber) and L76 manifold might be a good starting point.
Add on a cam and lifters to that kit (or a similar setup from SDPC) you will be close.
The cam will need to be match'd to the heads.
IE if the L92 heads were just cleaned up but not ported on the exhaust side then a larger split will be needed -vs- a set of ported L92 heads where the exhaust side is worked on extensively and the intake is just polished...
Me I was aiming for 425 and only hit 409... but its a nice daily driver setup (I put about 300 to 350miles on her a week).
