L92 head gaskets
Old Mar 11, 2007 | 07:45 PM
garrettpen's Avatar
Default L92 head gaskets
I was originally going to build a 402 so i bought a set of Fel-pro head gaskets with a 4.1 bore, now i'm just going to build a 6.0 with L92 heads will theese still work or should i buy a set of smaller bore gaskets?
Old Mar 11, 2007 | 09:46 PM
03 BUSA's Avatar
I would get a new set. You do not want to be pulling heads off after you just got done getting it back together. I would try to sell your other set of gaskets.
Old Mar 11, 2007 | 09:57 PM
ChevyThunder17's Avatar
What sort of head gaskets do the L92's require on an LS2? Standard 4.030 MLS/Cometics?
Old Mar 12, 2007 | 08:17 AM
See5's Avatar
The 4.1 gaskets are fine for a LSx. You need at least 4.06 for the L92s anyway so the 4.1s are commonly used. Race shops use them on everything. I am running them.
Old Mar 12, 2007 | 12:19 PM
garrettpen's Avatar
doesnt gm have a set of mls's for a 4 inch bore?
Old Mar 12, 2007 | 12:26 PM
camarols1's Avatar
The GM part number is 12610046 for the 6.0/6.2 truck engines.
Old Mar 12, 2007 | 05:09 PM
Richard@WCCH's Avatar
You'll be fine with that 4.100" Fel Pro gasket.
Good luck.
Richard
