zl402 into a 98 camaro?
Old Mar 11, 2007 | 07:48 PM
Stock Z's Avatar
Default zl402 into a 98 camaro?
im putting the slp zl402 ls2 into my 98 camaro......my question is im hoping to put down 600+ whp and im wondering if the stock computer will work for now.....if not can any1 point me in the right direction.....thanks
Old Mar 15, 2007 | 07:15 PM
Juiced's Avatar
i hope you plan on spraying it unless you plan on running 14+ compression and a huge cam........
Old Mar 15, 2007 | 07:22 PM
03 BUSA's Avatar
600 NA is not going to happen. With spray as stated above is possible. Stock PCM should work fine with a good tune.
