crane shaft mount rockers
Old Mar 14, 2007 | 08:29 PM
mrr23's Avatar
Default crane shaft mount rockers
all in a nicely packed box
one cylinder set up
rocker has a polymatrix bearing. no needle bearings means less friction loss.
Rocker stud towers had to be cut down .170" to fit the shaft mount. the holes had to be drilled and tapped to 3/8-16 thread pitch.
You can see where the valve cover wall had to be notched as well to clear the rocker. Also, on the right, you can see where the bolt boss had to be machined down.
stands on head
rockers installed
some close ups of the rockers. will need the 3/4" spacers to raise the valve covers enough to clear.
Old Mar 14, 2007 | 08:56 PM
MeentSS02's Avatar
Kleeborp the Moderator™
When do you expect the dyno results? Kinda wanted to see someone do a recent test of these...I know Tony Mamo has tested them with good results, but not much is ever said about them.
Old Mar 14, 2007 | 09:01 PM
mrr23's Avatar
i won't have any before/after test myself, as i'm putting these on a completely different motor. vinci has already done some testing on their C6 R&D car. they tested them against the 1.8 quick lift rockers and made 19 rwhp more with the 1.7 shafts.
http://vincihighperformance.com/C6%2...ON%20PAGE.HTML
Old Mar 14, 2007 | 09:06 PM
MeentSS02's Avatar
I see...that's really what I was hoping for - additional results. How much would you estimate the head machining would cost on average? Doesn't seem like it would be too hard, but I've never had someone do machine work on my heads.
Old Mar 14, 2007 | 09:10 PM
mrr23's Avatar
it cost me $200.00 just for the machine work to get the rockers to fit. with a complete valve job, it was $400.00
Old Mar 14, 2007 | 09:13 PM
MeentSS02's Avatar
Not bad at all...and they are a good price for a shaft mount system to boot. I'll have to keep these in mind when I get squirley with my engine...
