LS2 or L92 intake on LS1??? Please help
Old Mar 19, 2007 | 08:07 AM
1WickedLS1's Avatar
Default LS2 or L92 intake on LS1??? Please help
Im in the process of building a LQ4 based 6.0 motor for my 2000 Z28, And I was wondering what what it would take to use a LS2 intake. Or if i decide to use L92 heads what it would take to use a L92 intake.
Old Mar 19, 2007 | 08:28 AM
RGKSR's Avatar
Default L92 Heads = L76 Intake
Most people seem to be using the L76 intake. You can get it with the injectors (39 lbs), fuel rail, and a 90mm throttle body. If you have room the L92 truck intake will fit also.
They cost about $550 shipped.
Bob K. (RGKSR)
Old Mar 19, 2007 | 11:14 AM
HEMIETR's Avatar
If you choose not to go L92 heads and intake, I would opt for the LS6 intake over the LS2. It is a better flowing intake. If your looking to go with a 90mm tb, then look into a FAST setup.
Old Mar 19, 2007 | 05:40 PM
1WickedLS1's Avatar
im thinkin im gonna go with ported L92 heads, so im gonna go with the L76 intake, but what do i do about a thottle body sinse the one that goes on the L76 is not cable operated?? and a Ls1 based throttle body does not bolt up
Old Mar 19, 2007 | 06:38 PM
HEMIETR's Avatar
Buy a 90mm from Nick Williams.
