Which head gaskets for TFS 225 ?
What is the size of the combustion chamber on your heads?
Lot of the 4.00" bore head offerings seam to have a 4.100 chamber.
Any thoughts?
Any thoughts?
I have an update on compression ratio with the TFS 225 heads on a LS2 engine. I spoke to a customer of ours that goes by "rmitchell" on here, he has a C6 Vette with a stock LS2 shortblock. He originally had LPE LS6 heads with 11.5:1 compression and a 236/242 cam, he then switched to the TFS 225 heads and milled them to 12:1 compression. His power went from 480 RWHP to 507 RWHP, and the tendency towards detonation was actually reduced with the superior chamber design of the TFS heads.
I feel this is a better way to go than a bigger chamber with a thinner gasket, I prefer a quench of .040"-.050", it seemed to work for him, 12:1 with no detonation....
Should be fun to see what she does on a 385ci motor w/ a streetable cam.
Brian, sent you an e-mail.
