LS2 bore/piston specs...
Old Apr 6, 2007 | 10:52 AM
My90Iroc's Avatar
Default LS2 bore/piston specs...
I'm going to look at a used LS2 block and rotating assembly. The pistons are not in the block. I want to measure the bores to see how close they are to spec (block mileage is unknown). What should the bore size be in order for it to be within tolerable specs for stock pistons?
