SDPC Adjustable timing chain adjustment
Old Apr 7, 2007 | 04:43 AM
1dirtyZ's Avatar
Default SDPC Adjustable timing chain adjustment
i got the SDPC adjustable timing chain and was woundering how to adjust it ?
there are degree increments on the sprocket and the teeth, how do i go by adjusting it to lets say advance it 2 degrees? should i line the tooth that is marked +2 with the dot on the cam sprocket while installing the sprocket with the other +2 mark lined up with the key on the snout?
hope this makes sense
