6.2L stupid question
Old Apr 8, 2007 | 07:53 PM
Big Bird WS6's Avatar
Default 6.2L stupid question
with a 6.2L and L92 heads ported and L72 ported intake. with new intenals and stuff like norm. is it posible to get like a 9.5 to 1 comp ratio? and if so what is a good place to port?
thanks
Old Apr 8, 2007 | 08:15 PM
F8TEL402's Avatar
Send your heads to
http://www.proheads.com/
Richard has played with the L92 heads quite a bit.
Old Apr 9, 2007 | 01:43 AM
Bring the Noise's Avatar
Now if you were talking about stock L92 piston, rod, and crank then 9.5:1 is not going to happen. Because the L92's come from the factory at 10.5:1 with the 70cc heads.
http://www.gm.com/company/gm_exp_liv...lv10_02_en.pdf
But you are talking about a L92 Stroker (414 to 418).
You'll need to match up the -xx Dish size to the ported heads you plan on going with.
The reason I say "match up" is some of the Ported L92 heads are shaved .030" or so to get them down to a 64cc chamber. Where some are full deck height with the 70cc chambers.
Old Apr 9, 2007 | 05:27 AM
WKMCD's Avatar
That is incorrect. When Richard at WCCH CNC's the combustion chamber it adds about 6 cc. Give Richard a call. He can definitely set you up.
