Head recommendations for LS2 402... compression issue
Old Apr 24, 2007 | 09:16 AM
XtrmLS1spd's Avatar
Default Head recommendations for LS2 402... compression issue
I am looking for some recommendations for a set of hands to compliment a LS2 402.
Here's the current problem... compression. Right now, you can't run the correct timing in it with 93 octane. It wants to detonate and not run well b/c of it. Now, if you run the correct mount of timing (wouldn't it be 26*?) and use race fuel it runs about 90%. If you bump the timing down to 16* then you can run 93 in it just fine with no detonation. The heads on the car are a set of LS6 heads that have been hand finished, which are 5.3l heads and 61cc. At any rate, I believe that the heads are the problem. The cam in the car is a 250 256 .580 .580 108lsa. So wouldn't I need a set of 6.0l heads?
Any help is appriciated. Thanks.
Old Apr 24, 2007 | 09:37 AM
Stang's Bane's Avatar
What pistons are in the car??
BTW, the heads are either 5.3's or LS6 they can't be both. What are the casting numbers on the heads??
Old Apr 24, 2007 | 09:55 AM
XtrmLS1spd's Avatar
They are flat top nitrous pistons as far as I know. They could also be -14cc dish pistons. It's either or. I am just thinking about buying the car and trying to narrow down the possibilities to build it back up right. As soon as I get it and tear it down, we'll see what's in it.
Old Apr 24, 2007 | 10:03 AM
NoGamesLS1's Avatar
Well first thing you need to do is find out your CR
