ls2 w/ l92 heads cam question????????
By the way my car is an m6 so no worries about a conveter.
Bob K.
I don't have the Valvedrop for a l92 head with me at the moment to figure out the nominal clearance, but the lift at 110* and 106* to determine how large a cam you can use
With a 2.165 valve i'm guessing nothing larger than a low high 22X duration .588 lift. that still might be too close to call.
Tappet lift @ 110 or 106 (depending on ICL) X rocker ratio= Valve lift
Valve lift - Final valve drop (stock - total milling) + .040 safety = Valve relief Depth.
Thanks.
Bob K.
I'm using a similar set up and cam. Do you have any Dyno #'s....
