too tight bearing clearence!!!
Old Apr 27, 2007 | 05:49 PM
fstls2camaro's Avatar
Default too tight bearing clearence!!!
i got like 18 on the rods what should i do they are standard bearings
Old Apr 29, 2007 | 12:16 AM
machinistone's Avatar
First - what is your measuring method?
Old Apr 29, 2007 | 08:26 AM
White_Hawk's Avatar
On my GN motor, we targeted the rods at 1.5 to 1.8, and the mains to 1.8 to 2.0. We had to build those extra tight or they would lose oil pressure it idle, though.
-Geoff
Old Apr 29, 2007 | 08:01 PM
i used plastigage
Old Apr 30, 2007 | 10:03 PM
A machine shop should charge you less than an hours time to mic the crank and check your bearing clearance. Don't trust your motor to platigauge. If it turns up being too tight - they can polish a few tenths out of the crank and keep it perfectly straight.
