LS2 and LQ9, same piston, rings, right/ wrong?
Old Apr 27, 2007 | 09:57 PM
5150mechanic's Avatar
Default LS2 and LQ9, same piston, rings, right/ wrong?
GM parts direct says;
GM PART # 89017478
6.0L engine, 4.00" bore size, standard size 6.089" rod length floated pin type, 10.9 compression, 65 with chamber, hypereutectic LS2, and LQ9 replacement.
GM PART # 12499236
4.00" bore size, standard size, 1.5,1.5,2.5 mm ring thickness, set of 8 ring packs, standard size, for 1999-2005 LQ4, and LQ9.
GM PART # 88894243
4.00" bore size, standard size, 1.5,1.5,2.5 mm ring thickness for 2005-2006 LQ9, for one piston
GM PART # 89017484
4.00" bore size, standard size, 1.5,1.5,2.5 mm ring thickness, Production ring pack for 2005-2006 LS2, or L76. for one piston
07 GMPP catalog says;
89017484 4.00 bore 1.2, 1.5, 2.5 production ring pack for 05-06 LS2 and 06 L76
88894243 4.00 bore 1.5, 1.5, 2.5 production ring pack for 05/06 LQ9
Sorry to run this into the ground but has anybody replaced the rings on a LQ9 or LS2?
Old May 20, 2007 | 12:21 PM
Gregory J. Doyle's Avatar
I just ran into this on a set of LS2 pistons and they are definately 1.2/1.5/2.5 and I couldn't find anything aftermarket in rings, so I went with the GM 89017484 and they do fit nicely. I got them @ SDPC 1-800-456-0211. As far as them being the same as a LQ9 - I have no clue!!! I did use the GMPP site to find the LS2 ring numbers and all has proved to be factual - as mine fit. Hope this helps - sorry for the late post, but it took a while to get them as they are special order. I also wanted to fit them before I stated that they do work.
