ss trailblazer or ls2 questions
Old May 5, 2007 | 12:26 PM
slohatch91's Avatar
Default ss trailblazer or ls2 questions
will the comp roller rocker set just bolt onclick like those comp ones and can i run the 1.85's with stock valve covers?
and will i need a tune after installation?
and do they just install like any other rocker as far as lashing and stuff?
Old May 6, 2007 | 04:44 AM
Bring the Noise's Avatar
You will need to machine the stock valve covers or get a set of spacers.
Its not so much the rocker arms that cause a clearance issue. It's the Poly Locks that stand up so high off of the studs.
