LQ9/L92 Need Help!
Old May 9, 2007 | 07:59 AM
Y2K-WS6's Avatar
Default LQ9/L92 Need Help!
I have a 45k stock LQ9 Shortblock with true flat-tops and no valve reliefs. I would like to top it with shaved L92 heads and L76 intake. My question is how far can i go on the cam lift and duration without running into valve to piston interference issues?
I would rather not have to tear down this shortblock if possible, i was hoping to install a cam in the 230-240 range with over 600 lift but i fear these flat tops with no valve reliefs may not allow that. Thanks for your help.
Old May 9, 2007 | 04:46 PM
Y2K-WS6's Avatar
Does the Ls2 also have flat top pistons with no valve reliefs? If so surely someone has used L92 heads on an ls2 with an aftermarket cam? If you have what cam specs did you use? How much was L92 heads milled? and gasket thickness? and what clearance did you have between the valves and piston?
Old May 10, 2007 | 11:12 AM
Y2K-WS6's Avatar
ttt ttt
Old May 10, 2007 | 12:12 PM
Leadfoot1's Avatar
I have the same question. (sans L92's) and was told and read ± .630 lift and 237-240 was OK and thats what i'm looking at right now, i spoke with Dan at Wegner and Jeff at Lingenfelter, so they know what they are talking about, and they reccommended around .575 lift with same duration.
Hope this helps....
Anyone else?
Or try www.ls1tech.com
I posted the question there without an answer.
Lead.
Old May 10, 2007 | 12:13 PM
Leadfoot1's Avatar
Sorry man, i just got off Lateral-G and was still thinking i was there....
So might want to Here!
Lead.
Old May 10, 2007 | 02:18 PM
Y2K-WS6's Avatar
Thanks for your response, but this question is going to be L92 specific, since the intake valves are 2.16 as opposed to the much smaller LS1 valves that you have.....
Has anyone on here put L92 heads on an LS2 or any other 6.0L engine with stock pistons? If so refer to the above questions on the first of this thread please>??????????????
Old May 10, 2007 | 03:34 PM
98C5LS2's Avatar
I'm doing it this weekend. My fingers are crossed. Actually, I have a freind that had LGM do it on his C6 LS2. I think they used a .600 lift cam and a .040 gasket. I don't know the duration but it's an auto so it couldn't have been too radical. He's not sure and LG keeps pretty quiet about it.
Old May 10, 2007 | 04:33 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We build our PRC 6.2l CNC Heads with 145 valve drop & 64cc chambers. With our cnc program it allowed us to build the valve job to flow well & still keep decent p/v! My car made 440rwhp & 400lb ft using a automatic car & cats!
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 11, 2007 | 07:45 AM
Y2K-WS6's Avatar
Jason
Jason, Is this a LS2 build you are referring to? Did it have flat tops with no valve reliefs? I am a newbie so can you explain to me what "145 valve drop" means please?
What kind of lift and duration did the cam have in this car? If it did have flat tops with no valve reliefs what was the p/v?
Thanks for your help!
Old May 11, 2007 | 11:15 AM
stevewix's Avatar
my intake lobe, 220 @ .050" XE-R on LS2, .582 lift had .090" Intake PTV clearance.
Old May 11, 2007 | 01:03 PM
98C5LS2's Avatar
I assume un-milled head and stock L-92 gasket?
Thanks.
Old May 11, 2007 | 01:04 PM
Y2K-WS6's Avatar
Steve, This is some extremely helpful information! Thanks!!!!!!!!!!!! Do you recall if your LS2 pistons had any valve reliefs or were they flat top with no valve reliefs like my LQ9 ?
Old May 12, 2007 | 09:38 AM
Y2K-WS6's Avatar
ttt ttt
Old May 12, 2007 | 02:16 PM
stevewix's Avatar
Sorry, 108 ICL, .040" Mr Gasket MLS gaskets, milled .021" for 67cc chamber.
Old May 13, 2007 | 09:49 AM
Y2K-WS6's Avatar
can anyone tell me if the LS2 pistons and the LQ9 pistons are the same? ie do the LS2 pistons have valve reliefs or are they flat tops with no reliefs like the LQ9?????
Old May 15, 2007 | 12:49 PM
Y2K-WS6's Avatar
It seems that no-one knows just how much cam you can put in a stock 6.0L LS2/LQ9 shortblock, (using L92 heads with flattops and no valve reliefs) without running into P/V interference. I am ready to buy heads, intake kit and camshaft after this gets confirmed............. vendors listening??
Old Jul 9, 2007 | 12:08 AM
TRD's Avatar
TRD
Ever figure this out?
And what kind of power are you expecting?
Old Jul 9, 2007 | 02:43 AM
Faerus's Avatar
I'm wondering the same thing, about to pick up a LY6 engine and it's basically a LQ9 short block with L92 heads and I would put a L76 intake on it.
Old Jul 9, 2007 | 01:09 PM
97F1R408's Avatar
Last night I just fired up a lq9 shortblock with no valve reliefs stock 6.2 l92 head gaskets and stock l92 heads, springs only and a MTI Y1 cam which has .608 lift. Took it to 7000 last night = no issues. Hope this helps. I am curious what the compression ratio is with this combo?
Old Jul 9, 2007 | 04:55 PM
Awesomeperfmachine's Avatar
For those still wondering.... LS2 pistons are true flattops - no valve relief.
