are the l92 rocker bolts the same as the ls1?
Old May 10, 2007 | 01:47 PM
1dirtyZ's Avatar
Default are the l92 rocker bolts the same as the ls1?
just wanted to double check if the rocker arm bolt on l92 heads is the same as the one that is on ls1-2-6 rockers?
Old May 10, 2007 | 02:21 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Yes, they use the same bolts!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 10, 2007 | 02:33 PM
Stang's Bane's Avatar
What about the LS7's Matt??
Old May 10, 2007 | 02:46 PM
They are the same thread and pitch but different lengths and different part numbers. You might be able to make it work though, I haven't tried personally.
__________________
