What cam bearings for LS2 stroker?
ANYWAY - best mic your cam bores on 1-5 position to see if you have the larger 2.348, and yes 1-4 is 2.318, and 3 is 2.308 - as the center 3 bearings have remained the same sizes from early on. I AM BUILDING A 2003 IRONBLOCK - SO BE SURE TO DO SOME CHECKING OF YOUR BLOCK YEAR. I put the Durabonds in last night and they fit perfect. I did mic them up before I installed them to be sure. I hope this helps you. I got a new set of Clevite SH-1814S I won't be using until I build up an older year. If you want to make it easy - let your builder get them and save a lot of worry.
