LSx at the machine shop
Old May 17, 2007 | 03:45 PM
Phil99vette's Avatar
7 Second Club
Default LSx at the machine shop
I just dropped off all of the parts for my LSx build. Here is a run down of what we're going to do.
Switch over to 1/2" head studs for the standard locations
Switch over to 3/8" head studs for the two additional locations
Bore to 4.165
Machine receiver groove
Line Hone Mains using standard ARP fasteners
Setup main support system
Restrict lifter galleys to .060 using threaded insert
Diamond pistons to be machined to remove ~5cc
Balance rotating assembly
- Diamond pistons
- Howards Rods
We've got a custom torque plate being made and should be here 4-5 days setup for the new block.
Old May 17, 2007 | 04:33 PM
Noyzee's Avatar
8 second mod
sounds good!! let me know if you run into anything. mine is at the shop as well, he hasnt touched it yet tho, he has been sick for 3 days now
Old May 17, 2007 | 07:56 PM
7 Second Club
I'm trying to convince someone into making me a girdle like this...I won't say who tho. w
Old May 17, 2007 | 08:04 PM
koolrayz's Avatar
why not use restricted pushrods instead. there .040?
Old May 17, 2007 | 08:26 PM
7 Second Club
I'm doing everything we can to keep the oil in the pan. Its going to spin pretty high.
Old May 17, 2007 | 10:25 PM
Richard@WCCH's Avatar
Does the LSX block really need a girlde? I thought the main caps were supposed to be pretty tough. What kind of rpm?
Are you machining piston oil squirters too?
Your LSX block is going to be thoroughly stiff with a main girlde
Richard
Old May 18, 2007 | 07:15 AM
Noyzee's Avatar
8 second mod
you building a 6 sec car?
oh man it sounds like she will be bad ***, cant wait to see results
Old May 18, 2007 | 08:02 AM
7 Second Club
Richard
I really don't know IF it needs a girdle but it surely can't hurt. I'd like to have the ability to spin it to 8500-9200 if I need to.
Phil
Old May 18, 2007 | 08:32 AM
xssive's Avatar
Have this guy whip one up...http://dmperformance.org/new/newpage.html
Old May 18, 2007 | 08:34 AM
7 Second Club
I saw that one, I'd rather have one that ties into the rail/oil pan.
Old May 18, 2007 | 08:40 AM
xssive's Avatar
Thats what im saying, it would take him another 10 minutes to increase the thickness and tie in the pain rail on solidworks...
Old May 18, 2007 | 08:45 AM
ATVracr's Avatar
Damn Phil, is this going in the mustang?
Going to be SICK!!
CorvetteMajor's Avatar
7 Second/200 MPH Club
Phill
Sounds like a nice peice. I wouldn't think a girdle would be needed. I would consider a Jesel belt drive, lifter bushings and a dry sump setup. I have spun my LS2 setup to 8500 with no issues.
What heads are you planning to use?
Good luck
Old May 18, 2007 | 08:47 AM
7 Second Club
Originally Posted by CorvetteMajor
Phill
Good luck
Paul,
ET Performance LS7 setup for a 4.100+ bore.
Old May 18, 2007 | 08:49 AM
Originally Posted by Phil99vette
Paul,
Cool who's rockers and what are you doing for a stand?
7 Second Club
Going to be SICK!!
Wayne,
You know it. I'm hoping it will run a decent number.
Phil
Old May 18, 2007 | 08:50 AM
7 Second Club
Jesel setup some LS7 rockers for the ET heads with 3/8" ball adjusters instead of cup adjusters.
Old May 18, 2007 | 08:54 AM
Sound's good I just worry if you get real crazy with the springs pressure will it hold up thats why I prefer the C5R setup.
Old May 18, 2007 | 12:44 PM
Noyzee's Avatar
8 second mod
phil, who is doing your machine work?
my machinest just called said he cant touch mine for a month
Old May 18, 2007 | 12:50 PM
7 Second Club
Sent PM
