cam ?
heres the specs on the cam im looking into:
m Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-6,500
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 237
Duration at 050 inch Lift: 230 int./237 exh.
Advertised Intake Duration: 314
Advertised Exhaust Duration: 322
Advertised Duration: 314 int./322 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Valve Lift with Factory Rocker Arm Ratio: 0.540 int./0.540 exh. lift
Lobe Separation (degrees): 110
i want to go with the ls6 gm springs or will my stock ls2 springs with 14k miles ok? on tsp they say they are good to .550. so they should be sufficent correct? and i was also planning on running tsp pushrods just for safe keeping. the car wont be near a track for a long time. just want something that will give a solid increase in power and give it the old school goat cammed out sound. would this combo do the trick?
thanks,
chris
