valvespring alignment question, please shed some light on this....
The springs all look to be intact and the locks and retainers are all perfect, BUT the further forward spring on #7 (i dunno which is intake and which is exhaust :p) appears to be off center underneath the retainer....
Viewed from DEAD straight above, all the others seem to be more or less centered under the retainer.
The rocker tip on this #7 valve is still centered over the valve stem (so i don't think the valve is bent) but the top coil (just under the section that flattens out to seat to the retainer) is almost completely visible on one side, and really not at all on the opposite, where all the others have about the outer half of the coil visible out past the retainer.
The strange part is that the flat portion of the top coil is more or less centered against the retainer and the bottom of the spring looks to be pretty much centered against the spring seat.
The best way I can describe it is that it appears the spring is either slightly out of round starting halfway down the top coil, or the spring is actually compressed "out to one side" a little.
My digital camera software isn't loaded up on the comp yet, so here's a quick and dirty MSpaint to give somewhat of an idea what i'm talking about...(left is the way the other seven look, right is this strange one)
Is this a problem? the motor actually does seem to sound pretty much the same on both sides when I put my ear right up to each valve cover and the car seems to run normally.....what's going on here?
Someone posted in my other recent thread in this section (the 918 springs thread) with pictures of EXACTLY what my situation looks like.
He had 10 springs sitting shifted like mine....they all had the top coil broken....
