would stock ls7 lifters hold up to this cam?
that occures in my procharged camaro from 5800 and up:i have a set of prc double springs on my heads and a .655 lift and 266 duration cam, could this be causing the stock ls7 lifters to collapse?
The lifter can handle as much lift as you can throw at it as long as the you have the proper parts. Spring Seat Pressure and open pressure is going to determine if the lifter is going to collapse or not.
If you are Running a Titanium Valve, with a light spring, proper pre-load, the proper length pushrod you can use a hydraulic lifter no problem.
If you start mismatching components like a Heavy Stock valve, 500+ open pressure spring and stock ls1 lifters yeah your are going to destroy the lifter.
