couple quick questions about an ls2 swap
are the map sensors the same, just on a different part of the manifold, or are they different?
is the cam position sensor the same, and just moved to the front, or will i need a different cam position sensor?
i tried using search but its being gay to me so some quick help is appreciated
I beleive the lifter trays are the same.
Don't know, used a L76 intake.
The cam sensor uses the upper cam timing gear and sensor on the front cover. Totally different from the LS1.
I milled my heads 20 thousands and I'm running Manley dual springs/ti Retainers with a 5 angle valve job. I used FelPro 1161 (.051) head gaskets.
My 402 is up and running and the only problem I had (other than forgetting to connect the harness at the rear of the car) was the blade on the t/b hanging up on the body. I think it's fixed now.
I changed the oil & filter after 100 miles and it seems to be running great. I got a mail order tune from Carlie @ RPM and the car ran great from the start. On the 19th I'm going to Cartek for a dynotune, that way I also know how much RWHP/TQ I've got.
Bob K.
