What is the most efficient SB?
Old Jun 13, 2007 | 01:40 AM
joebas's Avatar
Default What is the most efficient SB?
hi, new here, and aside from some strange threads this place seems to be pretty knowledgeable about smallblocks. So I have a question:
In terms of wringing the maximum efficiency from a smallblock, which is the best choice? I'll qualify that further by adding the requirement that it be streetable, from off-idle to wherever the peak may lie (no motors optimised for a narrow RPM range)
thoughts?
Old Jun 13, 2007 | 02:44 AM
78novacaine's Avatar
for one, would prolly get better responses in the small block forum. but are we talking all year smallblocks? or just older stuff, cuz any year i would have to pick an ls7 crate motor - 505 very streetable hp from the factory out of a small block. and for older style sbc's, i would think a 400 small block or 383 stroker with midsize cam and a good set of heads would be your best bet for all around power
Old Jun 13, 2007 | 10:26 AM
joebas's Avatar
Any year, but thinking the later stuff is probably wringing more HP per cubic inch (normally aspirated)
I guess I should clarify, I am curious about efficiency in terms of maximum power per unit of fuel consumed, not overall absolute power.
Old Jun 13, 2007 | 12:03 PM
Torovair's Avatar
Default define efficiency..
Which measure of efficiency are you considering?
MPG, BSFC, Thermal, Mechanical, HP/cid, HP/lb, HP/$ ???
Old Jun 13, 2007 | 03:07 PM
joebas's Avatar
as stated: "power per unit of fuel consumed"
(Brake specific fuel consumption would be equivalent, although the inverse - easily translated. Highest efficiency or lowest SFC)
Figuring the best gasoline engines are somewhere between 30-35% efficient, just wondering where the sweet spot for any of the small blocks is, and which is the best of the best.
