Biggest cam on L92 head?
Old Jun 23, 2007 | 03:34 PM
speeddemongto's Avatar
Default Biggest cam on L92 head?
I have the TSP Magic stick 3 coming,is this too big to run with a L92 head setup?
Old Jun 25, 2007 | 08:36 PM
ttt,anything?
Old Jun 26, 2007 | 04:55 AM
cybernco's Avatar
I thought my cam was big, but a lot of people have told me that it's average for my size engine.
Old Jun 26, 2007 | 05:55 AM
See5's Avatar
If I told you "sure go ahead" would you expect me to fix it for you if you ruined the heads?
My point is you better mock it up and measure given all the variables.
Old Jun 26, 2007 | 06:37 AM
Stang's Bane's Avatar
do you mean lift wise?? Or are you talking about the durations??
Old Jun 26, 2007 | 08:16 AM
SUTTERERMAN85's Avatar
yea i think 230's -240's is typical nowadays. well i mean more the norm, 250's+ is big to me.
Old Jun 26, 2007 | 08:17 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
It will help get more accurate replies if we know what bottom end you have as well.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jun 26, 2007 | 09:54 AM
LSInnovations's Avatar
Im running a 242/250 with success in my l92/l76 setup.
Old Jun 26, 2007 | 10:05 AM
silver-mod-o's Avatar
Custm2500's #1 Fan
in a truck at that
-good luck on your 10 sec pass BTW
Old Jun 26, 2007 | 11:08 AM
Eric Hawkins's Avatar
What bottom end are you running?
Thanks
Old Jun 26, 2007 | 02:43 PM
LS2 bottom end
Old Jun 26, 2007 | 03:33 PM
LS2 bottom end
Stock bottom end LS2? And are you opposed to flycutting your pistons?
__________________
Old Jun 26, 2007 | 03:53 PM
BADSZ28's Avatar
You should call a shop who sells these heads. Like SDPC/\/\/\ or Livernouis >>>.
Old Jun 26, 2007 | 10:24 PM
LS2 bottom end
Wow, have you checked the Piston to Valve clerance?
Old Jun 27, 2007 | 02:34 AM
thats what I am trying to find out!
not totally,as long as it is not a total pain to do
Old Jun 27, 2007 | 11:59 PM
hmm I keep looking at more and more L92 setups on a stock LS2 block that are running bigger and bigger cams
Old Jun 28, 2007 | 12:02 AM
without flycutting
Old Jun 28, 2007 | 02:20 AM
Thanks
6.0 block, eagle crank/h-beam rods/ mahle pistons
Stock l92 heads /w 9.7:1 compression (runs on 87 octane for most driving, 91 for the track), l76 intake, 242/250 cam etc etc.... made 454 rwhp on 87 octane with old 23x/23x camshaft..
Old Jun 28, 2007 | 05:48 AM
See5's Avatar
There is really quite a bit of room under the heads as the chambers are ~70 you will no doubt want to mill heads to gain compression, chose a cam then check clearance.
