removing DOD on l92 block?
Old Jun 25, 2007 | 05:54 PM
sroka's Avatar
Default removing DOD on l92 block?
How are you guys going about removing the DOD on the l92 blocks? Just changing the valley cover to a ls1 or ls6 cover and tapping and plugging the holes in the lifter valleys?
Old Jun 25, 2007 | 06:49 PM
HTMtrSprt's Avatar
That is correct.....
Old Jun 25, 2007 | 10:39 PM
drain89's Avatar
I thought that with the L92 block when using the L92 heads and L92/L76 intakes you just had to switch to the LS2 valley cover which would eliminate the need to plug the holes.
Old Jun 26, 2007 | 05:38 AM
sroka's Avatar
So which it right?
