LSx 6 bolt Head gaskets
Old Jun 29, 2007 | 07:17 PM
Tiago's Avatar
Default LSx 6 bolt Head gaskets
What are the options and part numbers?
has felpro released theirs yet?
thanks,
Old Jun 29, 2007 | 09:34 PM
qqwqeqwrqwqtq's Avatar
When I called fel-pro they had no idea what I was talking about. (though it's likely because I wasn't talking to the right person, he wouldn't direct me to anyone else)
I ended up buying a few sets from Cometic.
Old Jun 29, 2007 | 09:37 PM
Quickin's Avatar
SCE Copper gaskets
Old Jun 29, 2007 | 10:27 PM
OneQuickCoupe's Avatar
Cometic has them but you will need to call for the part number. They have a left and right as they are different.
D.J.
Old Jun 29, 2007 | 11:26 PM
NA$TY-TA's Avatar
How much do they run???
Old Jun 30, 2007 | 04:21 AM
I called Cometic Thursday and they list around $90 each. I would believe they could be ordered from a vendor for less money. SDPC is one of many that handle them. The part numbers below are for .040" crush thickness.
Left, P/N H2570SP1040S
Right P/N H2569SP1040S
D.J.
Old Jun 30, 2007 | 09:05 AM
Tiago's Avatar
is the cometic gasket a MLS gasket?
I haven't seen a very good track record on those
Old Jun 30, 2007 | 10:30 AM
WOW I haven't heard that out of the Cometic's. I do know however that if you don't surface the deck and heads properly there may be a problem. You have to machine the surface's with at least a 50 RA surface finish or finer or you may have a problem.
D.J.
Old Jun 30, 2007 | 12:45 PM
Quickin's Avatar
D.J.
My cometics are perfect, so far, after one year and 25,000 miles. All I did was hand sand the block surface with sand paper and my head guy resurfaced my heads.
