LS3 blocks...
Old Jul 18, 2007 | 02:51 PM
RWC's Avatar
RWC
Originally Posted by ringram
Yep, I recon the "new" truck block is the L92 as opposed to the old LS2 style.
But hey the intake changed a little over the L76 so you never know.
The "new" truck block is really the LS3 block as opposed to the old L92 style. I hope it replaces all 6.0L aluminum engines in the future. No real need to have both.
Now if GM would just put a 4" crank in it for the new Camaro..........
Old Jul 18, 2007 | 03:22 PM
z28hustle's Avatar
thats just what we need... more cubes MUAHAHHHAHAHAA
now what kinds of H/C/I packages will be coming around ... i hate to void a warranty so fast... oh well
Old Jul 18, 2007 | 03:26 PM
1ORANGEWS6's Avatar
Who needs a warranty anyways?
Old Jul 18, 2007 | 04:27 PM
slt200mph's Avatar
I never had to use my factory 3 year/36,000 mile warranty and I now have 136,000 miles on it. Only had to replace two items outside of regular maintenance and doing mods ... Replaced the clutch when it blew at 75K and the driver's side power window motor crapped two months ago..phuch a warranty..
Old Jul 19, 2007 | 08:49 PM
z28hustle's Avatar
well im getting a bigger crank asap...
Old Jul 20, 2007 | 02:48 PM
gun5l1ng3r's Avatar
What would the displacement be with a 4" crank, and how would the ring packages and pistons(that WILL be in LS3,not special LS7 or race type;production) hold up to that stroke?
I haven't been following pistons parts closely enough to know what the max long-lasting stroke is....
Old Jul 20, 2007 | 04:22 PM
RWC's Avatar
RWC
It would be 416 CI and is available from several venders. Some on here have that combo using the L92 block and seem to have good luck with them.
Old Jul 20, 2007 | 10:52 PM
drain89's Avatar
What's the difference between the blocks?
What pn is the new block?
Old Jul 21, 2007 | 12:48 PM
ChocoTaco369's Avatar
Tech Resident
Originally Posted by allngn_c5
30 + rwhp should be expected.
pfft, 500 rwhp has been hit in an LS1 block. i'm thinking more like 550 - 600 rwhp in an LS3!
Old Jul 21, 2007 | 09:14 PM
drain89's Avatar
Probably so. In a couple years after the pro's have had some real time to figure out the L92 heads and camming, I think those numbers will be typical.
