Cam sensor problems, Help?
Old Jul 18, 2007 | 09:03 PM
Whistler74's Avatar
Default Cam sensor problems, Help?
I just got done changing my LS1 to an LS2. I made a post about a week ago about a cam sensor problem I was having. Code 343 Cam position voltage hi. I was told to swap the two outer wires on the cam sensor and that would solve the problem. Now after swaping the wires I get a code 342 Cam position Voltage low. What am I doing wrong???? Anyone else have this issue?
Old Jul 19, 2007 | 11:58 AM
Nasty N8's Avatar
There are alot of bad sensors out there we just went through the same thing but had no cam signal at all. replace the sensor.
Nate
Old Aug 4, 2007 | 06:23 AM
hallsj1's Avatar
Try this, reply #7 to be more specific. This was extremely helpful for me; turns out I had both mixed and a pinched wires.
https://ls1tech.com/forums/showthrea...75#post7123575
