LS7 RPM Limit
Old Jul 20, 2007 | 09:18 PM
jkittleson's Avatar
Default LS7 RPM Limit
Why do all of the LSx engines usually only turn up to 7000 rpm?
Can they not handle 8000+ like the "old" small block chevy engines? Both of my circle track engines turned 8200 rpm, with stainless valves, good springs and mechanical roller cam.
Is the hydraulic cam the only thing holding them back??
Old Jul 20, 2007 | 09:29 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Hydraulic lifters, valvetrain geometry, and limited spring sizes are whats keeping the rpm down.
Old Jul 20, 2007 | 09:36 PM
jkittleson's Avatar
So if you upgraded to solid roller, good valve springs and Jesel you could turn these things up to 8000? I wonder if the LS7 heads and intake would still make power up there?
Any downsides to running solid roller on the street besides frequent valve adjustments?
Old Jul 20, 2007 | 09:40 PM
RC45's Avatar
Something like Ferrea springs?
Old Jul 20, 2007 | 09:50 PM
jkittleson's Avatar
Oh man...not you again!
Old Jul 20, 2007 | 10:05 PM
RC45's Avatar
One more word and I will debut the car with a 150 shot on top of the LS7...
Old Jul 20, 2007 | 10:13 PM
jkittleson's Avatar
I know I should have ordered the supercharger...
Old Jul 20, 2007 | 11:34 PM
Old SStroker's Avatar
Sure 8000 is possible with an LS7-based engine but you have to do everything right. Depending on the displacement, correctly ported LS7 heads can probably support 427-450 cubes into the low-mid 7s power peak area.
With the large intake valves, mass (weight) is a problem as is strength to withstand the acceleration loads the valve sees in the 8000 rpm range. You certainly would have to use the best (stiffest, lightest, lowest inertia) valvetrain parts. That might actually be the limiting factor if you are planning to use the lobes you need to move the wind. I'm not sure if the currently available stuff can hack the job. Yes, solid roller, and springs are available but not necessarily at Jegs or Summit. None of this stuff is cheap; it's outright friggin' expensive.
If you want to play in the big sandbox you not only need deep pockets, you need to find the right parts. Some of them may still in someone's imagination or on the back of an envelope. If we find that LS7-style heads can support over ~2.2 hp per cube in 7-8L NA engines in the next few years, the valvetrain pieces will become available. They may rival the cost of the full-blown ported and dressed heads, but as Stroker McGurk once said: "Speed costs money; how fast do you want to go?"
I liked a lot of the things Stroker McGurk said.
Old Jul 21, 2007 | 01:37 AM
chicane's Avatar
Katech's "Sneak Attack" has been around for quite some time... and it has an 8000RPM redline. Not to mention that it is a 'street' worthy package. So, I am sure that Jason could explain the limitations thus far. Jason... ??
I believe it to be near 100% valvetrain related. The cam, lifter's and rocker assemblies are my guess. Ti valves, shaft assemblies, mechanical lifters and a more aggressive camshaft could easily polevault an LSx into 8k plus RPM use.
Without braking a sweat I should add...
Old Jul 21, 2007 | 06:05 AM
FastPacedGTO's Avatar
whats the big idea?? 7000 is alot of RPM anyway...
Old Jul 21, 2007 | 07:27 AM
Katech_Jason's Avatar
LS1TECH Sponsor
I beg to differ. The limit is piston speed. At 7000rpm with a 4.000" stroke, mean piston speed is over 4600fpm. Very high for an endurance race engine let alone a production engine. Sure there are drag race engines with rediculouly higher piston speeds, but coming from an endurance racing engine builder, its high enough for us.
The short stroke Sneak Attack LS7 uses production LS7 valvetrain with Cadillac Racing's high speed lifters and revs to 8000rpm.
Old Jul 21, 2007 | 07:40 AM
See5's Avatar
With the stock and most intakes the power is dropping pretty fast past 6,200 so you might be better of playing with the lower rpm torque.
Old Jul 21, 2007 | 08:59 AM
RC45's Avatar
Hhmm.. I have seen a few dynocharts now, and the LS7's seemed to still be making healthy power past 7,000 - so why short change yourself?
7000 to 7100 rpm, 26" tyre, 3.42 rear end - you have a healthy 200 mph 5th gear and carry 60mph in 1st.
All specifications the C6 Z06 meets readily in stock form - so with 600+ crank HP a tweaked LS7 is a great high hp/high speed super sports car power plant
Hell - with the right power + 150 wet shot, 7000rpm and 3.15 gears, an LS7 powered C5 has a good shot at 200mph in the standing mile I should imagine.
For a number of excercises it would seem rpm is important to get the right work out of the torque a setup produces.
Old Jul 21, 2007 | 09:32 PM
jkittleson's Avatar
Thanks Jason, that makes sense. The motors I turned over 8K were 3.48 stroke, one with 4" bore and the other 4.125". I guess it makes sense with the 4" stroke is to turn less rpm "7K" and use all of the torque.
Old Jul 22, 2007 | 12:00 AM
chicane's Avatar
Ah... yes. Thank you for turning the lights back on. I dont know why, but that did escape me at first thought.
Old Jul 22, 2007 | 01:29 AM
bowtiguy's Avatar
I just took a ride in a certain Colorado based LS7/Z06 that had the redline owner adjusted to 8K..1st gear burn out was bouncing off the 8K redline with nothing more than a glorified ls1 cam ( from a well know endurance motor vender..available at 1/2 the price FWIW) and a spring/retainer change. all else in valvetrain land was stock.
This could quite possibly be the fastest steer car I've ever ridden in since driving a modified 97 TT 911. I'd have more concern for losing the big end of the sodium filled exhaust valves at high RPM/Lift than anything else.
