Cd Z06 Piston to valve clearcance?
Old Jul 21, 2007 | 11:04 AM
kelp's Avatar
Default Cd Z06 Piston to valve clearcance?
Does anyone know the piston to valve clearance in the C6 Z06?
The only internet reference is 7mm / 8mm which is clearly too high. Thanks.
Old Jul 22, 2007 | 06:12 AM
Haans249's Avatar
7 and 8mm is definitely not too high on a stock cammed, low lift, low duration, high LSA/ICL cammed motor with valve relieves in the pistons. Easiest way to know if just measure yourself, it shouldn't take any longer then an hour to do using a dial indicator and check springs.
Best Regards,
Adrian Mejia
Old Jul 22, 2007 | 11:10 AM
John B's Avatar
Moderator
There's a friggin' ton!!! I measure mine at TDC and the numbers were 0.357" on the intake and 0.380" on the exhaust Sounds like the 7mm & 8mm were right when measured at ~10° BTDC.
Old Jul 23, 2007 | 07:49 AM
kelp's Avatar
I do not think/remember that the figures I got were at 10* BTDC, but since yours were are TDC, that changes my cam design considerably! I wonder why all the aftermarket cams stay below 0.100"
