Building the ultimate LSX...what heads?
I would contact Tom Nelson or find anything he has on the web about turbo theory, he seems to have a handle on it. I am not saying he is the best, but he does have a pretty good track record
Like I said, a good racer with a proper setup can make big power with a small head, the bigger heads don't pick up a turbo combination like they do N/A, Supercharged or Nitrous due to the bigger heads having big intake valves that promote exhaust gas dilution into the intake port. Most any turbo application has more pressure on the exhaust side than intake side, this is what causes the exhaust gas to go back into the intake port during overlap. Most big heads also have corresponding big exhaust ports, that is not what a good turbo head needs to be. I would have an exhaust port smaller than 100cc, I would think closer to 90cc, and no bigger than a 1.60" exhaust valve, and don't hesitate to go steep seat angles on intake and exhaust, it will help minimize the reversion (dilution)
Turbo engines also like smaller exhaust valves and exhaust ports, so don't be tempted to run a nitrous type of exhaust port.
Turbo engines don't tend to need as good of a head to make power as a N/A, blower or nitrous setup. I have seen Ford racers go low 7's with 225cc heads.
Gas dillution is definately a problem but if its a problem on a FI turbo engine then it should be a problem an NA motor if the exhuast was that wretched.
I refuse to play the velocity game becuase its a wasted argument. you can have small ports with insane local velocitys or you can have large ports with low local velocitys. from what I have seen the port with the best overall average velocitys, and the least amount of low and high velocity zones. That is a port with good average speed throughout with out any higher veolcity or lower velocity zones will always be better then said small or large port.
I would not be lumped into either group saying that a small port will work better then a large port or vise versa. A good exmplae of this is the L92/l76 Gm head. I have seen tremendous power out of these heads and intakes but the trick is in realizing how camshaft specficiations can totally screw this head up.
Thats like how most people ignore the relationship between exhuast efficiency and the effectiveness of overlap. Put to much overlap into a closed muffled exhuast system and watch power drop like a rock.
thats gets back into your arugment on intake port backing up with exhuast.
Same with a turbo application.
Still boggles my mind, that a motor could run effectively at all, with higher exhaust pressure than intake pressure. Just doesnt make sense in my little pea brain.
I understand the theory, and why, just am kinda
Sorry for the hijack. Just wanted to comment on that remark.
Most of the turbo kits out there today flat out suck.
I'm probably the first guy on this site who let everyone know how important cam timing events are on a L92 head and got bashed, it is so sensitive to cam timing events due to the oversize intake valve.
Once you understand the pressures in the ports and how they interact with each other during overlap you can better understand what makes certain combinations work better than others. Which also means you can probably understand why I say a big intake valve on a turbo application can be a problem, and also why reducing the low lift flow (.100"-.200") actually helps the thing make more power. You can classify smaller intake valves or steeper seat angles as "intake anti reversion tactics"
I posted it before and I will post it again. I had a C6 Corvette customer with an APS TT kit with a stock LS2 short block and heads. He removed the stock 243 castings and installed L92 heads and intake and lost 40 HP.
What was the combination that you spoke of? What were the heads?
Most kits run 1.5:1 ratio of exhaust pressure to intake pressure, it is when the ratio gets to 2:1 that you have REAL problems.
i reckon the list should start with the turbo's-like choose the turbo u want for their rating-then move to the ehaust manifold set-up then to the heads to suit turbo+pipes+then valvetrain gear+then to intake set-up to injectors-then short block-
i have seen others go out and buy big stuff only to cry when they don't get what they want-
i reckon its down to matching things to things for the application-
i think we have all seen hi-tech combos and basic combo's-the basic one 80% of the time runs problem free and makes more hp-torq-
this combo needs good planing from the get go-
2000hp would be insane-thats for sure
lets see some pics and progress when the time comes-
Long story short, spent some time on the phone with Gale Banks and some others, only to find out it was normal.
And yeah, I can understand the "check valve" theory, how it works, and how you can manipulate both the intake and exhaust valves and seats to keep down the reversion.
Pressue and Pulse.
A constant pressure drive system runs at high back pressure out of nessecity. A Wave Pulse system runs at the minimum pressure possiable.
A constant pressure system mashes all of the exhuast pulses together into one constant stream of back pressure. This is the bulk of turbo charging system out there even with good headers and merge collectors.
A wave or pulse charging system works alot differently. A wave system basically works like a good NA header. IT uses each individual pulse to drive the turbine one pulse at a time. This requires a very large turbine area or a very well laid out waste gate setup.
Banks has been at turbocharging for a long time but if you ask him about the differences between constant pressure and Pulse driving he has loads of info.
Pulse systems typicall run at half the intake pressure if they are working well. There is some good info on the ecotech drag car engine development and how they achivied the pressure cross over.
they all flow great, and its a turbo motor.
to be honest, it really doesnt matter. pick one of the six bolt heads with a nice thick deck, pray it stays on, and if it doesnt make enough power... shove more air in there until it does.
LOL, I like the way you think, but gambling with this kind of price tag is a little stupid. I'd rather do the research and come up with the best theoretical combination, that way if it doesn't make the power I can't say I didn't do my best...
If it was a street car with a T-76 single... you bet I'd just throw it together and turn up the boost!
thing is, its not really a gamble.
you only have a choice of a great head, a great head and a great head.... no one makes a crappy 6bolt head. lol.
your only other options would be:
how do i want to port/modify these castings
or
a totally custom head (like the canted valve ETP)... and thats most likely out just due to price...
if it was me, i would go with the stock castings.. and worse case, if you dont like it, pop off the heads and have them ported... its not like you wont be popping the heads on and off occasionally anyway, its a race motor.
i donno, i suppose im on a "just do it" attitude kick.. i know exactly where you're coming from.. thats a lot of cash to just make a casual decision... but of your choices, i really dont think the head will end up being the deciding factor for this motor. you cant buy a crappy flowing 6bolt head.
