L92 Heads Cam
Old Aug 21, 2007 | 10:56 PM
bhop42's Avatar
Default L92 Heads Cam
Does anybody know how big of a cam can go into one of the new 6.0l engines that come with the L92 heads (L76/LY6) without running into trouble? Also has anybody removed the cam phaser and installed a LS2 timing set? My LY6 below.
Old Aug 23, 2007 | 10:57 AM
FirstGen's Avatar
What are you wanting to run? All depends on where the cam is degreed and what lift/duration.
Old Aug 25, 2007 | 12:17 PM
bhop42's Avatar
I was thinking about something in the 22X range for intake duration and around .590 lift. What size cam have some of you guys ran on stock 6.0 bottom ends without running into piston to valve clearance issues?
