LQ9 Iron block build-up...
Old Sep 4, 2007 | 04:52 PM
NCTURBOS's Avatar
Default LQ9 Iron block build-up...
So... I'm starting to gather some parts to do an iron LQ9 build-up and I have a bare block. Is the oem LQ9 front cover the one to use or the F-body, or...?? Also where can I get the rear cover from? Just used or...??
This will be going into a hybrid vehicle, I don't own a LSx powered car/truck, that's why I'm having to start from scratch.
TIA,
K.
Old Sep 4, 2007 | 05:36 PM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
TIA,
K.
The LQ9, LS1 Vettes, and F-Body cars used the same front cover. We have the rear covers new or used in stock.
Old Sep 4, 2007 | 10:57 PM
NCTURBOS's Avatar
Brian,
Do you mind giving me the GM part# for the rear cover? Also, when looking at the parts computer @ work it lists different part#'s for the front covers per LQ9 vs. LS1, but are you saying that side-by-side they're the same??
TIA,
K.
Old Sep 5, 2007 | 10:15 AM
bg-sdpc's Avatar
Brian,
TIA,
K.
In the GM electronic catalog we have a function that allows you to put in a part # and it will tell you all the applications the part number is used for. It shows all LS1 / LS6 cars and also truck applications up to 2007. I even looked up a 2005 LQ9 and it shows the same cover as a 1998-2002 F body.
The rear housing part # is 12615666.
Brian
