L92 Valves @ 6500 rpm
Old Sep 9, 2007 | 11:06 AM
racecar's Avatar
Default L92 Valves @ 6500 rpm
Will the stock L92 valves work for road racing at 6500 rpm? What's the popular theory, go for it, or buy aftermarket valves from Manley.
I'm reading that the LS3 valves are hollow stem and may not be quite as strong. How about the L92's are they bullet proof?
Old Sep 9, 2007 | 12:36 PM
See5's Avatar
Stock L92 valves are strong although intakes are a bit heavy. With aftermarket springs (PSI) only, the engine shows no head problems on dyno to 7200rpm. We tracked a LS7 for hours with stock valves and PSIs it was flawless shifting @ 7k. I ran them on 402 with 0 problems.
Running the LS3 head, ported in a week or so and with PSIs again, expect no problems.
Old Sep 9, 2007 | 01:05 PM
racecar's Avatar
Wow, Good input. If you are running them to 7200, that proves that they will take the rpm without falling apart. How much spring pressure are using to get to 7200? That must be dual springs and solid cam?
Old Sep 9, 2007 | 01:18 PM
See5's Avatar
As with any GM intake power starts dropping @~6100 so there is no real good reason to over rev unless you are in a no time to shift situation.
We have run L92s with LS7 lifters, Patriot golds and the PSIs.
PSI LS1511
Endurance Spring: Single- Beehive LS1 & LS6 (O.D.: 1.290") (I.D. Outer: .630") (I.D. Middle: N/A) (I.D. Inner: N/A) (Seat Pressure: 120lbs.@1.800") (Open Pressure: 360lbs.@1.175") (Rate Lb./In.: 384) (Retainer Step: .000") (Max Lift: .625") (Coil Bind: 1.100").
The Nascar Spec motors run these >8k with ti valves.
Old Sep 9, 2007 | 02:06 PM
Bink's Avatar
PSI LS1511
Great info!! THANKS!!
Old Sep 9, 2007 | 08:08 PM
njc.corp's Avatar
I AGREE-
Old Sep 9, 2007 | 08:13 PM
racecar's Avatar
See5; The spring specs that you posted, will those work on these L92 heads with bigger valves. With more valve weight do I need a bigger spring.
Old Sep 9, 2007 | 08:18 PM
See5's Avatar
That spring is proven with the heavy valves. If you have not bought the heads yet you could use the LS3 intakes and save a few grams. I am putting the first set together that way now, but don't expect much difference in performance.
Going to dyno both ways but it will be a few weeks.
Old Sep 14, 2007 | 03:57 PM
Louis's Avatar
Stock L92 valves and 921s @ .050 of coil bind will control to 7400. I have not dynoed that setup past that
Old Sep 15, 2007 | 01:44 AM
racecar's Avatar
Now that rocks since I am planning to shift at 6500.
Thanks for the real world information.
Old Sep 15, 2007 | 01:15 PM
Haans249's Avatar
I put another vote for the 1511 springs. I have them in my LS7 application with big lift (650int/670exh) and run them to 6.5K rpms, and not a hint of valve problems. They're really a great spring.
Old Sep 15, 2007 | 02:11 PM
WKMCD's Avatar
What manifold are you using at 7400 RPM and L92 valves?
There is nothing wrong with the stock L92 valves. They are back cut nicely and the weight is comparable to aftermarket valves. Just because there are aftermarket valves doesn't mean they are any lighter.
BTW: I hit my 6800 rev limiter somtimes/often with 921's no problem. They are setup correctly though.
Old Sep 15, 2007 | 03:22 PM
Louis's Avatar
Stock, with a big cam
Old Sep 15, 2007 | 09:38 PM
blue by you's Avatar
I read somewhere that the stock valves are 2-piece and the stock LS3 intake was lighter because it's hollow and it's a 3-piece valve. If this is true, what kind of durability are we talking here?
