Help with my Afr Heads
Old Sep 9, 2007 | 07:14 PM
Vr6aaron's Avatar
Default Help with my Afr Heads
Can someone help me here, I am new to this so any help would be great.
I have AFR 205 heads 66cc noN milled. I want to install either Cartek 2x cam or some other cam. Do i need to get these things milled? If so to what. What does that mean anyway? What are they out of the box? Anyone know.
Thanks for any replies. Oh by the way this is going in an ls2 corvette. Thanks
Old Sep 9, 2007 | 07:26 PM
JRracing's Avatar
They come with 66cc chambers, so if you want them milled you need to know the exact specs on the cam so you do not run into piston to valve clearance issues. Mine are milled to 58cc's with a .651" lift cam but I have pistons that have .150" valve reliefs cut into them with a cometic .040" head gasket.
Contact Cartek on the cam specs and how much you should mill off of them.
