W2W 427 Pictures
Old Sep 16, 2007 | 10:52 AM
Vindication's Avatar
Originally Posted by njc.corp
getting back to topic-i like the comp ratio-and it will be okay-
pics look good-
whta heads and inlet u using-auto or manual any more details and pics would be good-
hope all goes well-
I should have more pictures tomorrow. Im using All Pro LSW Heads with a LS7 intake manifold.
Old Sep 16, 2007 | 11:12 AM
stevegrizzle's Avatar
I think you made the right decision, you only want to pay and build this thing once and If you are running 91oct a higher compression ratio would mean you are running closer the limits of the motor.
The guys that are running high boost high CR's are mostly track only guys, or at least run some form of race gas. If you want a slightly higher CR you could always have the heads milled correct?
Old Sep 16, 2007 | 02:00 PM
WhiteDeathLS1's Avatar
Mark,
I think you made the right decision with the CR. Unless you plan on leaving Cali soon...
Old Sep 16, 2007 | 02:38 PM
OneQuickCoupe's Avatar
Did Richard at WCCH do the CNC work for you?
D.J.
Old Sep 16, 2007 | 02:50 PM
4SFEDZ's Avatar
sick!!!!!!!!!!
Old Sep 16, 2007 | 03:17 PM
CraZee ZO6's Avatar
I think cr is ok too with cali gas and emissions. Just run some big boost, biggest you can on pump safely and you will be happy. Then throw in some race gas and turn it up and watch out! (if you wanted to go nuts at the track)
Old Sep 18, 2007 | 11:48 PM
Richard@WCCH's Avatar
Nice combo you have here Mark.
I think your compression is just right for a pump gas boulevard brute. Sure more initial compression will be pedal happy, but too much pedal pedal response on street drivers becomes a chore to drive on a daily basis (been there and done that ). The compression difference means a loss of maybe 20+ft/lbs of torque off boost. Your combo will have enough grunt to blow off the tires on oil slicked So Cal streets.
You've spent money on high quality parts and W2W will do everything in their power to make the engine live. That bears significant weight when matching combinations and components.
Enjoy that hot rod
Richard
Old Sep 19, 2007 | 05:44 AM
FraggerCrue's Avatar
Originally Posted by Tiago
It will come down to your ultimate goals, power with pump gas or race gas?
race gas= raise the CR to 9.0 or higher.
Pump gas= leave it as is.
Or add Methanol injection maybe wired up with a WOT switch, so it would be safe all the time on the street.
Old Sep 19, 2007 | 06:14 AM
njc.corp's Avatar
Cool
sounds good-
Old Sep 19, 2007 | 02:24 PM
427's Avatar
427
Default Marks Z06
A picture of the car out back, can you pick out the one thats not a black Z06?
Kurt
Old Sep 19, 2007 | 06:12 PM
haha, from a far my HREs don't look much different than the stock wheels.
Old Sep 19, 2007 | 08:12 PM
  #32
Superman09's Avatar
LS1Tech Sponsor
Looks awesome man, i cant wait to see the car in person when i go in on Tues, ill make sure to tell it that you miss her, haha
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Sep 19, 2007 | 09:04 PM
  #33
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
LOL at the Del Sol.
Here's what he posted in another thread. These heads are sick!
Well today I met a bunch of good guys over at West Coast Cylinder Heads. Richard and I believe his name was Dave (sorry if Im wrong) gave me a good lesson! I got to look at a few different styles and designs. Richard really took a lot of time to explain his work and his products. The guys over there know their stuff! Here are my set of All Pros. Originally I was suppose to get some ET Heads but I guess things didn't work out with them so here I am.
Here is a picture of the Jesel Rocker with MoHawk Option which is required for these heads.
PS: 1900th post!
Old Sep 19, 2007 | 09:43 PM
  #34
Thanks guys.
Old Sep 21, 2007 | 10:27 AM
  #35
TNTramair's Avatar
Kurt
looks to be the one in the middle....no bumper scoop.... what do i win????
nice set up by the way! CR should be fine as its been said...goodluck with the rest of the build
Old Sep 21, 2007 | 10:38 AM
  #36
Thank you sir. Looks like I'm set to have a long winter.
Old Sep 21, 2007 | 12:57 PM
  #37
Tiago's Avatar
looks great Mark!
Old Sep 21, 2007 | 01:04 PM
  #38
Slowhawk's Avatar
LS1Tech Sponsor
Good move on replacing the sleeves.They would of went early.
As for compression I do agree with Peter because the APS kit is known for running small turbo's.A higher compression would yeild more power.Now if the turbo's were bigger then the 8.5-1 would be good. Either way I would definitely run an adder with it.91 octain is pretty low for the big $$ project you have.Atleast run a meth kit.
Old Sep 21, 2007 | 01:19 PM
  #39
Thank you for the comments
yeah, the sleeves were just insurance. I was scared of the LS7/Boost rumors.
Well, not sure if you have followed the forums much but there have been some changes with the Turbos. The APS Z06 kit will not be used on this car but another company (can't say who it is yet ) has stepped up and will be the provider. I believe the turbos on this kit will flow a bit more but I don't have all the specs. We will see what happens....
I do plan on using the Alky Control set up from Julio or the ECS. I haven't decided on one yet.
Old Sep 21, 2007 | 02:57 PM
  #40
Black Sunshine/ 00SS's Avatar
Nice build. You have made some good choices, and a good place to build it. Keep us informed..
