need l92 block part number and info
Old Sep 21, 2007 | 11:09 PM
Willem @ Fuel Injection Concepts's Avatar
Default need l92 block part number and info
is it shipping yet? is it as strong as the truck 6 liter iron blocks or is it an even better casting?
can i install a normal lsx cam / timing chain setup or is the casting different because of the cam phasor? are the sensors in same location as ls2 or ls1 block?
and last but not least, part number and is it shipping yet or still not out?
Old Sep 27, 2007 | 08:41 AM
69LT1Bird's Avatar
The bare block is 12584727 released by Performance Parts. Its aluminum and weighs only 138 lbs.
The cam phasing part is its own timing chain setup, using a standard one will work fine. Sensor locations appear to be the same as the 6.0L.
Direct replacement for 2007 L92 6.2L
Production aluminum block with iron sleeves
Production oiling system
6-bolt iron main bearing caps
9.240" deck height
Use only LS1, LS6, LS2, L76 or C5R cylinder heads
4.065" finished bore (103.25mm)
Great for stroker cranks for even more cubes
