Need Help! Pushrod Size??
Old Sep 26, 2007 | 10:39 AM
765joey's Avatar
Default Need Help! Pushrod Size??
Hey guys I was needing to know what size of pushrod do I need. As of right now I have a set of 7.4's in. It's a 402 Just stock LS6 heads off my old LS2 for now. They are NOT milled. Using LS7 lifters, stock rockers, With stock GM Head Gaskets. I was reading something about the LS2 / 243 castings with non sodium filled valves takes a longer p/r than the ls1 / 243 casting sodium filled valves due to the non sodium valves are a shorter valve stem? Any help would be appreciated.
Thanks
Old Sep 26, 2007 | 03:52 PM
66deuce's Avatar
Thanks
i would get an adjustable pushrod and make sure you have the correct length..with aftermarket cams having smaller base circles,LS7 lifters,why not spend just a little more money and time to make sure you have the right geometry..could be leaving a little power on the table if you don't check it..
Old Sep 26, 2007 | 03:57 PM
765joey's Avatar
Thanks for the help. Calling Speed Inc as we speak.
Joey
