Gaskets.. Head/Cam Swap..
Old Sep 29, 2007 | 06:20 PM
Tram's Avatar
Default Gaskets.. Head/Cam Swap..
OK guys..
I am in the final stages of planning the head H/C swap..
I only need to pick up a set of LS7 Lifters, proper injectors, head bolts and some gaskets..
I just want to make sure I'm not missing anything..
I plan on picking up
- Set of head gaskets
- 2 Water pump gaskets
- 1 front engine seal
Are there any more gaskets I am missing? Any O-rings, etc?
Thanks
Jeff
Old Sep 29, 2007 | 07:49 PM
1Hotbird's Avatar
You might want a front main seal.
If your going to take off the oil pump you will need a o ring for the pickup tube.
You might want the 4 seals for the steam tubes? (you could probably re use the old ones)
