5.3 heads work on a L92?
Old Nov 2, 2007 | 03:06 PM
matchstick's Avatar
Default 5.3 heads work on a L92?
Will my 5.3 truck heads off my Ls1 work on a L92?
Old Nov 2, 2007 | 03:57 PM
jay_lt4's Avatar
i just have to ask why,, the whole point of having a L92 is in the heads
Old Nov 2, 2007 | 04:58 PM
S1LV3R's Avatar
Maybe he can't afford everything at once and needs to use the old heads until he can afford new ones? So will the heads work?
Old Nov 2, 2007 | 05:37 PM
Grimes's Avatar
I'm thinking that the compression ratio will be way too high w/ 5.3 heads
Old Nov 5, 2007 | 04:59 AM
matchstick's Avatar
Well, lets see. I have a 382 right now with TEA heads and a FAST 90/90 setup. I want more cubic inches. That make any sense?
Also, there's no such thing as too nuch compression.
Old Nov 5, 2007 | 11:05 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
He was referring to running on pump gas. You can do all sorts of tricks though to keep your dcr down.
Old Nov 5, 2007 | 06:37 PM
ZLEEPER's Avatar
I ran a set of AS 5.3 heads on my 402 for awhile until I got the L92's. No problems as long as you don't run a huge cam with severely milled heads.
Old Nov 5, 2007 | 06:45 PM
HTX's Avatar
HTX
