550+ RWHP LS7? Is this possible?
Old Nov 19, 2007 | 05:49 AM
njc.corp's Avatar
from what u guys say and from what i read i here the factory ls7 heads are the **** and they flow good numbers from factory-
with that said a good selection in cam wise should get u their?????
Old Nov 25, 2007 | 11:49 AM
Mr Z51's Avatar
Originally Posted by gen3performance
Just wondering what it takes to make 550 plus at the tires with an LS7 and a T56. Naturally aspirated and no spray.
Here is a list of mods on 06 Z06
Calloway CAI, 160stat, Kooks 1 3/4stepped to 2", Off road X, Ported Intake, 231/249 113+3 Designed my me and Goeff(Thunder Racing), All Tune work done by me.
Old Nov 25, 2007 | 06:27 PM
venom ws7's Avatar
Nice result man you should race GT500 again.
Old Nov 27, 2007 | 03:38 PM
1998silverbird's Avatar
Now what kind of drivabilty and MPG do you see with that setup?? Just wonderring..
Old Nov 27, 2007 | 09:10 PM
Mr Z51's Avatar
The cam is really mild for this car. To me it drives very similar to a 224/224 cam. The car has more cubes so it swallows up the cam nicely. It surges very little, but only below 1500 in 4th and 5th gear. In 6th there is no surging at all. Still get 24-26 on the hwy and runs 10's all day long.
Old Nov 27, 2007 | 09:18 PM
Bill00Formula's Avatar
Mr. Z51, What is your car's trap speed in the quarter mile. I've seen a lot of pretty high dyno numbers on the Z06s but not too much quarter mile info.
Old Nov 27, 2007 | 10:47 PM
Mr Z51's Avatar
10.62@130.94
Video: http://www.youtube.com/watch?v=Pbglo-IUtD0
Old Nov 28, 2007 | 10:02 AM
OneQuickCoupe's Avatar
Strong numbers for the mods you have. That 60 is outstanding as well. Stock tires or DR? The engine sounds like you really hooked on the hit. Do you think the surge a low rpm's can be worked out? It's interesting that it will surge in the lower gears then straighten out in 6th. Nice job.
D.J.
Old Nov 28, 2007 | 11:59 AM
Mr Z51's Avatar
Its been worked out. Its barely there. You will never get it to run completly like stock. It has a cam and with that there are some things to live with. Let me put it this way. I said it to be fair, but my wife doesn't notice it, so all is well. It doesn't do it in 6th because there is more load on the car in 6th. The object to get the car to stop bucking is to get a good load on the motor in those other gears through air flow, fuel, and timing. I ran those times on 17'' ET Streets.
Old Nov 28, 2007 | 12:45 PM
Thanks for filling in the blanks for me.
D.J.
Old Nov 28, 2007 | 02:56 PM
JakeFusion's Avatar
Super Hulk Smash
If you do a search for the QM600 cam for the LS7, you'll see it's pretty much in the 540-550rwhp range. With ported heads, people are seeing very close to 600 with that.
LG has their G7X series of cams and the top dog there with ported heads has put out 620rwhp.
Katech's cams are doing 550rwhp as well with the right combination of parts.
550+ is very doable in the LS7.
Old Nov 28, 2007 | 03:35 PM
  #32
I searched the QM600 cam. Sounds like it makes some power in a larger engine. I didn't see any spec's on it however.
D.J.
Old Nov 29, 2007 | 12:10 AM
  #33
Mr Z51's Avatar
Carlos does not give the cam specs on his cam in public forums. I can tell you that the cam in my car is very very close in design to the QM600. Cam works great in an LS7 Z06. If you are interested in a cam I would advise you to call Thunder and talk to Geoff. He would probably tell you to the same cam as in my car. Works very well and makes excellent numbers. I just ordered a set of hand ported heads from HPE today. I am hoping for 580-600rwhp.
Old Nov 29, 2007 | 06:48 PM
  #34
ramairws6's Avatar
I have the QM600 cam that you guys are discussing and I love it! It's a little bit bigger then MrZ's cam and has the idle and drivability very decent right now with just a little bit of tweaking to do. I had a much smaller cam in before this and honestly the QM600 idles and has better driveability then the smaller one. Really it's all in the tune! Traver
Old Nov 29, 2007 | 08:43 PM
  #35
Bink's Avatar
Any 1/4 times or dyno #s on your build??
Old Nov 29, 2007 | 09:06 PM
  #36
Dragkid1917's Avatar
A car that gets 24-26 mph and runs 10's at over 130 is damn impressive. Also Id say that 550 Rwhp with a 427 isnt that hard, and many combos can hit that number
Old Dec 2, 2007 | 04:17 PM
  #37
C_Williams's Avatar
07 Z06 with 239/251 cam - Re-worked LS7 heads - Dynatech Headers - Ported Intake and TB -
Old Dec 2, 2007 | 04:38 PM
  #38
Bink's Avatar
Crank HP - I assume?
Who did the heads, TB and intake porting?
Old Dec 2, 2007 | 08:10 PM
  #39
Mr Z51's Avatar
No thats rear wheel. Z06's are great NA cars.
Old Dec 2, 2007 | 08:47 PM
  #40
C_Williams's Avatar
As Mr. Z51 reported - rear wheel
All work done at the shop that tuned and dyno'd the car.
