LS3 with fast intake
Old Nov 18, 2007 | 06:23 PM
lhaitzss's Avatar
Default LS3 with fast intake
i was in the process of gathering parts for a 383 build, but recently changed plans. I have a good fast intake with a nick williams throttle body. If i buy an ls3 block is it possible to still use the fast intake or do I have to get a new one to match heads. I tried looking for information on this but seems very far and between. Is it possible to run a standard ls1/2 type of head? Thanks any info would be great.
Old Nov 18, 2007 | 06:30 PM
jay_lt4's Avatar
ports are different on ls3 heads compared to ls1,, yes you could run ls1 style heads on a ls3 block
Old Nov 18, 2007 | 06:37 PM
lhaitzss's Avatar
Thanks for the fast response. Would I be leaving anything on the table if I were to go with an aftermarket ls1/2 head rather than going with a ls3 style head? Would I need to do any modifications to use an ls3 style intake. This is possibly going to go in a 1998 camaro if it makes any difference. Would it be easier to do an ls2 block? I alreday purchased a Callies 4' stroke crank. Would this work in the ls3 block also. Thanks again
Old Nov 19, 2007 | 06:01 AM
njc.corp's Avatar
the crank will fit in a ls3 block-
