what cc head should i go with??
Old Dec 21, 2007 | 08:36 AM
rpmauto's Avatar
Default what cc head should i go with??
Well, i am finnaly ready to get some heads for my 402(aluminum block), i am going with a ls6 style head. I want to be able to run pump gas with no issues, and i will be sprayin a 150 shot at the track (unless they boot me for not havin a cage). My short block has 2cc JE flattops, and i want to run a cometic gasket. How much compression should i be looking at running?? I called my machinist that has my motor now to ask if the pistons come out of the hole at all, he has it apart now so he did not know for sure, but he said he thought that they did not. I guess my biggest concern is that i dont want detonation issues, but i dont want to leave a ton of power on the table. I see on here a lot of guys runnin 11.5:1 and they say they are on pump gas with a 60 something chamber. Is a 72cc chamber too big?? I only want to do this once, so i would like to get it right. Thank you for any advice.
Old Dec 22, 2007 | 06:53 AM
rpmauto's Avatar
any ideas, for the morning crew
Old Dec 22, 2007 | 08:40 AM
slow trap's Avatar
it depends on the cam you are going to run, what is the specs of it ? if 93 is available you cam probably get away with dcr up around 8.8 or maybe even alittle more without issues.
