which crankshaft?
Their is (2) companies I know of with crankshafts contracts in China I would stay away from, an eagle crankshaft is 100X better and easier to balance then these scrap jobs. None of these companies have been mentioned here.
IDK
I think I know one of those places you are talking about! We have had some stuff I had to have the crank grinder here true back up and essentially take .002 off of and then use some coated bearings to get round journals and teh right bearing clearance. I have seen some crazy Eagle big block Chevy cranks in the past and some SCAT small block Chevy cranks that were not so good. OTOH the good SCAT stuff is usually very nice. I've even seen some bad Lunati stuff even lately where the fillets were messed up right out of the box. It all depends and you always have to check.
Would the Compstar rods work better with a Compstar crank than Eagle rods would?
and the Eagle has (or can be ordered with) L19 bolts i think? Heard those were pretty strong too.
Is the price difference worth getting the Compstar over the Eagle?
As far the crank, arent they all more or less equal (off shore cranks that is)until they machine them? Yes material comes into play but arent the Callies and Eagle both cast in China? The higher the price the more machining invloved to lighten it up and bring it within tighter specs? Isnt this the real difference? The machining and if your going to have the crank worked over in the first place then why would it matter? Isnt that called balancing the rotating assembly? So what we're talking about here is time to balance the crank right? Please correct me if I'm wrong, it's good education for the board and myself.
I've never gotten one of these engines that I couldn't fix or figure out the problem in once we had the engine apart for at least 5 minutes. I did two more for Vendors on the right that had extreme or mild smoking problems alone right before I left for Seattle and I have two more that will be fixed when I return. Even the 4.000 inch stroke stuff is always being blamed for extreme oil consumption and it's really almost never anything to do with the dimensions whatsoever but rather with the thought (or lack of thought) that went into the parts to make that assembly.
No the different 4.100 and up cranks are different forgings of course not castings but I think you know that. Some are almost the same and some are different. The machining is definitely a lot of what makes it a good crank as far as sizing and stroke indexing and accuracy and the heat treat and the fillet radius's used and the geometry of the journals. The journals need to be round and straight and have no taper etc.
This is all more easier said than done and the Callies stuff is definitely somewhat better in this respect for sure at this point and time. There are also different qualities of 4340 steel and there's also the oiling hole clockings etc. Then you have balance and total weight on any particular crank. There are a lot of differences if you really use these cranks everyday and they all have their applications and uses.
I try to get people to put their money where it will help them the most and not in a crazy overly expensive crank and rods (Lunati) which will do almost nothing to make them faster or more reliable. These parts are always great parts but compared to higher end valve springs of heads or intakes and lifters etc they are almost a total waste of money. I do think the Callies stuff is a good blend of bang for the buck with outstanding quality and I use their stuff in the higher end builds and the Compstar and Eagle in the less expensive builds.
You have to dress the face of the cutting wheel regularly to keep it clean and flat. It does not take much taper or out of round to ruin a good crank.
The good companies have good equipment, good quality control, and of course good core material to work with. Most of the cranks we did were cast, but we occasionally woul cut some steel cranks also. I took pride in the cranks I did, but I saw some real junk go through the shop. Needless to say our QC was not good.
I have Hee-Haw luck
No gapless rings used by me (or any OEM in the entire world which might tell you something) although I use lots of C and A and Total seal regular rings. They are both great companies which make great products. I just haven't seen any real gains or good come of them especially considering the price.
Thanks for all the info guys........please keep it coming!Traver
