LS1 to a ls2 or ls7 what will i need
Old Dec 26, 2007 | 05:59 PM
sl99ls1's Avatar
Default LS1 to a ls2 or ls7 what will i need
i just messed up my ls1 in my 99 z28 its blowing oil out the tail pipes. so im planing on getting a ls2 or ls7 short block, but i was woundering what can i use off my ls1 like my heads and pullies ect and if it will my stock parts please let me know
thanks
Old Dec 26, 2007 | 07:08 PM
njc.corp's Avatar
Cool
thanks
ahmm=the thing's u could use from memory is the pullies+rocket covers--
your heads would fit on all ls engines-but would u put ls1 heads on a ls7- i would not-won't feed enough air for the cubes u are thinking of-
and u could use the exhaust
ls1 intake on a ls2 would work+fit but not on al92 or ls7 head-(square ports)
ls2+ls3+ls7 timming case+valley cover is not the same (cam sensor in the front timing cover)
thats all i can think of now has i am a bit how u going-
Old Dec 26, 2007 | 10:29 PM
sl99ls1's Avatar
so its better going with an ls2 short block because i could use more things from my ls1
Old Dec 27, 2007 | 12:58 AM
njc.corp's Avatar
Cool
that is correct-
Old Dec 27, 2007 | 03:51 AM
onoiocoko's Avatar
ive heard running smaller heads would give u higher compression for NA making more horse power. like 305 heads on the old 350 = more power. true or myth anyone?
Old Dec 27, 2007 | 05:58 AM
Deeavi's Avatar
AFR 225 Heads will make plenty of power on an LS7 shortblock, but you have to make sure you have the right pistons for LS1 type heads.
That is what I am building!
