LS2 Starving Oil Pressure Thread
Basically the oil pressure started to slowly diminish over a long period of time, a few PSI a week but would fluctuate back up--so it seemed like things were working. Until one day it began dropping very fast and never came back up, which is when I parked it and tore it apart.
Here's the thread:
http://www.ls1gto.com/forums/showthread.php?t=209067
So I'm still wondering if it was the cause or the effect. Everything else seems ok. I've got a new Melling HV pump on order to replace the stocker with.
That is the reason for the oil pressure drop. Have someone check the cam tunnel bore with a dial bore indicator to make sure it is still with-in spec and if it is, clean the block, lock in some new cam bearings and put it back together.
Best of luck,
Brian
